I’m adding notes in the widget table. The links are being displayed, but they appear as long, unreadable URLs. Is there a way to display a word as a clickable link instead of showing the full URL?
If you are adding links in a widget on the canvas you can select some text and click “Insert text link” in the Interactions pane under Common interactions.
If you are adding links in the Notes, there is not a way to set a display word.
