An error has occurred
when the error occurred : Exception has been thrown by the target of an Objective-C method call.
Hey @jax, thank you for reporting this error. We apologize for the issue you see and would be happy to investigate it. Please send us the repro steps and the affected .rp file at support@axure.com so we can reproduce the issue on our side.
Meanwhile, if your file was closed, you can restore an earlier version of your file by following the steps detailed in the link provided below:
I tried multiple times and found that the crash may be caused by the Chinese language pack I added. However, I was able to use the language pack without any issues before. The crash occurred before I updated Axure or macOS, so I can preliminarily rule out these two reasons. Moreover, even after updating to the latest macOS and Axure versions, the crash still occurs.
In addition, my Mac has an Intel chip, and I’m using the latest macOS version and Axure version.
Please help me find a solution.
Hey @jax, can you tell us if Axure RP crashes when you don’t use a language pack? If Axure keeps crashing without this language pack, please send us your Axure log files at support@axure.com so we can investigate what might be happening. You can find these log files in the following location:
  • *Mac (open the Finder and use “Go > Go to Folder” to paste the file path):
    ~/Library/Application Support/Axure/Axure-10-0/logs
axure10 doesn’t crash when I don’t use language pack
Perhaps your package caused Axure’s crashing, changing to another package may be helpful
  1. But my language pack has been used for several months, and axure has never crashed.
  2. I also replaced several other language packs later, and the same crash will occur
It seems that your package is old and incompatible with the new Axure RP version. If you can return to a previous version of Axure RP, there should be no problem
It’s not like what you said. When the crash happened, I didn’t update the version of axure. It just crashed suddenly during the use process. I didn’t come and save the rp file, and the language pack could be used normally before the crash.
So this crash problem, can anyone help me out?
这个可能是汉化包导致的一个错误,您可以试试新的汉化包:https://www.axure.com.cn/84384
因为有用户反馈了跟你一样的问题,更新后可以解决。
您好,这个问题我们已经找到问题的根源了。请参考此文章即可解决:https://www.axure.com.cn/89114
