The inspector panel does not render correctly at least once a day.
The application crashes at least once a day.
Due to crashes, I’ve lost work many times.
I love the application and have used it for years, but it’s simply not reliable anymore. Looking for alternatives
We apologize that you’re running into these issues and would be happy to help.
If the application crashes unexpectedly or if you want to revert back to an older version of your project, you can take advantage of the auto-saved backup files which by default are saved every 15 minutes. You can find these files via “File > Recover File from Backup”.
You can also change the internal at which these backups are automatically saved by navigating to “File > Preferences > Backups”. Hopefully, this will allow you to reduce the amount of work lost.
Can you send us your RP logs so we can see what errors the application is picking up? You can find these files via “Help > Show Troubleshooting Logs”.
Then, can you let us know if there are any patterns or related events that seem to occur before the crashing? For example, are you working in a specific file and/or a specific type of action or widget when it usually happens?
It would also be helpful if you could send us a copy of your project file as well. If preferred feel free to send any files or details to us at support@axure.com.
