Axure 11 beta 导出的本地 HTML 文件 无法实现浏览器预览。
HTML 文件 无法通过本地浏览器预览,无法通过 start 文件开始预览;
内联框架组件在预览中失效,无法实现点击交互多层级的动态面板;
团队中一人失误更新团队文件后,其他成员都会被动强制升级到 11,否则团队文件会无法使用。但是目前升级到 11之后的 RP 文件 是无法退回到 10 的,这一已经对我们团队造成了影响。
从本地备份文件夹找找吧。版本升级是无法回退的。
照提示说明,安装Chrome浏览器插件,并且打开允许本地文件访问。
参考:http://www.hiaxure.com/thread-19498-1-1.html
不是插件的问题,是11还没有做好兼容。我有按照了预览的插件。 在浏览器和蓝湖都存在这个问题。
Hi @ziyer!
I’ve had to translate your message, so I apologize in advance for any miscommunication.
Browser preview is not possible for local HTML files exported by Axure 11 beta.
HTML files cannot be previewed through the local browser and cannot be previewed through the start file;
The inline frame component fails in the preview and cannot realize multi-level dynamic panels with click interaction;
If one person in the team accidentally updates the team file, other members will be forced to upgrade to 11, otherwise the team file will become unusable. However, the RP files currently upgraded to 11 cannot be returned to 10, which has already had an impact on our team.
To troubleshoot the local HTML issue, could you write in to support@axure.com with any additional information you’re able to provide, such as the browser you’re using to preview, the OS you’re running (Mac, Windows), and any screenshots of what you see in the browser when trying to view the local HTML.
For the upgrade team project issue, your team can revert the upgrade from RP 10 to RP 11 by going to the History tab for the project on Axure Cloud (app.axure.cloud) and selecting “Revert Upgrade - Return to RP 10”. Here’s what that would look like:
Once you select the Revert option, please note that this will restore the team project to the last published RP 10 check-in and make it compatible with Axure RP 10. All RP 11 check-ins made after the last RP 10 checkin will be removed and the check-in history will be lost.
