Axure Cloud Maintenance Friday, February 11 2022 3pm-4pm PST (Completed)
Axure Cloud will be down for maintenance this Friday, February 11 2022 from 3PM-6PM PST.
During this time Axure Cloud will be in read-only mode, which means you will be able to view prototypes, but will be unable to make any changes or publish to your Axure Cloud links. If you need to publish and share a prototype during this time, we suggest publishing your file locally through the Generate HTML feature (“Publish > Generate HTML Files”).
We anticipate this will only take an hour or less, but please write in to support@axure.com if you have any questions or concerns. Thank you!
Update 4:23PM PST:
Maintenance is taking a bit longer than expected. Currently we expect Axure Cloud to be back up and out of maintenance closer to 6PM PST. Thank you for your patience!
Axure Cloud is now out of read-only mode. Publishing and updates should work as normal again. If you encounter any issues please don’t hesitate to reach out to us at support@axure.com. Thank you!
