Hello, is there a way how to “save” normal .rp file as a library? I’d like to have my content available in the library but there seems no other option than manually copying and pasting all assets I have in my .rp file…
Hi, agilek. You can’t do it with a save, but if you create an empty library you can use File > Import from RP File to pull pages in from that file.
J
Actually, you can do it. I do not know if its the best way, but
- Close the file.
- Change the extension from .rp to .rplib
- Later you can pull that file as library using Load Library in other RP files
Let me know if it worked! Cheers
Worked for me, thanks
