Specifically it’s not rendering things in the cloud or in preview the way things are designed in the file. The only way to make it go away is to add padding to the box that I have text inside of. Any reason Axure cant render these with NO padding properly (as designed)?
Thanks in advance.
Has anyone dealt with this? I use Axure for work and really need to understand this bug/feature
Bump
Anyone? Axure people? Do you monitor these forums?
Hi @lex.windle,
If you could email your .rp file to support@axure.com, our support team will be able to help you out through there. Thanks!
