Stay up to date on the latest beta channel builds of Axure RP 11 in this thread! Please keep in mind that the downloads mentioned here are for beta builds that are still in testing. If you run into any bugs or unexpected behavior, please report them to support@axure.com.
Download at Axure RP | Beta or via Help > Check for Updates in RP 11 Beta.
Axure RP 11.0.0.4107
BUG FIXES
Fixed issues around rendering SVG shapes in preview
Fixed issues with SVG shapes in adaptive views
Fixed components in repeaters resetting their position in preview
Fixed components not appearing when unplaced in the Base view
Fixed hard crash when swapping a component instance within itself
Fixed shadows on shapes not rendering properly on Mac
Fixed shapes disappearing when adding shadows on Windows
Fixed gradients getting removed after repeater refresh
Fixed table cell borders rendering thicker in preview
Fixed Console interactions not appearing if file name contained an apostrophe
I’m sorry to hear about the lag. Could you write in to support@axure.com and let us know the following:
Is the lag specific to the most recent build (11.0.0.4122), or have you experienced the lag with previous builds? Or is the lag specific to RP 11 in general?
What OS are you running? (e.g. MacOS 15.2, Windows 10, Windows 11)
Is the lag specific to typing, or do you experience it with other actions, e.g. moving a widget?
If you could also send us a screen recording of the lag or any other information that’ll help us to troubleshoot the issue on our end, that’d be helpful as well. Thank you!
I had to translate your message, so I apologize in advance for any miscommunication.
Not only is it very lagging (the typing response is slow), it is always Caton Caton, which is loaded with Caton in one or two words. collapse. UB
It sounds like RP 11 is running slow on your machine, is that right? To investigate the slowness, please email our support team at support@axure.com so we can further investigate the issue. Any additional details you’re able to provide, e.g. screen recording, error logs, etc., will be helpful. Thank you!
I checked this release and while the issue related to notes on elements on components inside dynamic panels are fixed (great news ), I have found a new issue related to notes on table cells inside dynamic panels, they have dissappeared :(.
I hope you can look into this regression issue before releasing the new version.
Sorry to hear you’re still running into issues with the new build. I haven’t been able to reproduce the table/dynamic panel note bug - could you write in to support@axure.com with a copy of the .rp file where you’re seeing this issue? Thanks!
