Recently updated to Mac OS Catalina. Axure RP 9 and 8 do not work anymore. Any idea when Axure will release update to Catalina?
Is there any workaround to start Axure RP 8 and 9 on Catalina?
Hi! The latest builds of Axure RP 8 and 9 are compatible with macOS 10.15. However, 10.15 also has new security prompts for apps that are not from the App store; we’re looking into that on our end, but in the meantime you should be able to launch Axure RP if you go to “System Preferences > Security & Privacy > General” and click on “Open Anyway” next to where it tells you Axure RP failed to launch. That should do it, but let us know if you still run into trouble!
Thanks @Alyssa_Axure for your support, appreciate it. Axure RP 9 is now working but RP 8 does not load. Glad that atleast RP 9 is working.
What about optipng? Go64 says this component used in Axure 9 is not 64bit compatible.
When I contacted support, they sent me a response as if it should work normally.
I wasted a lot of time with support & got nothing at the end!
( Case 3701875)
Let’s wait & see
There is no “Open Anyway”!!
Even I didn’t see “Open Anyway”.
What made Axure RP 9 work is opening the file through Finder. Open Finder, go to Applications and locate Axure RP 9 icon. Press Control key, select Axure RP 9 icon and then choose Open. This shall work.
Hi all, sorry for the delay! We’ve just released a notarized build of Axure RP 9 that should allow launching on Axure RP 9 even with the security prompts. Details are noted in the thread below:
