There is a requirement where I want to show three circles, which are intersecting with each other and need to show a common intersection point.
Something like this:
Is this possible?
Regards,
Apurvo
Is this possible?
Regards,
Apurvo
Hi apurvo,
I did shapes in illustrator with one of this tools:
and
Thanks Natalie
I am aware that this is possible in illustrator, but I guess in Axure we can’t create this using Shapes.
Thanks for your prompt reply, appreciate.
Depends if you want 100% control over the colors.
If you don’t, then you can do this:
It’s simply a case of setting colors with a bit of transparency.
You can create the shape in Axure by right-clicking multiple selected shapes and selecting “transform shape.” I uploaded an example to the linked thread:
Jeff
Thanks, appreciate your quick revert.
Regards,
Apurvo
Ah OK - I was assuming you wanted the intersection calculated “live”
