For the last couple of days, I get this error message when I try to check-in my team project:
I also cannot publish it. What is the status of this issue? When will this be fixed?
Hi C.Power,
Axure Share is currently up and running normally right now. Are you still running into this error? If so, and if you haven’t already, please try restarting Axure RP to see if that does the trick. If you get the same error after restarting, then please email support@axure.com with the Axure Share ID of the affected team project so that we can take a closer look. Please also let us know whether only this particular project is affected, or if you see issues with multiple files (both team projects and regular files). Thanks!
