你好,
在使用最新版Axure软件过程中发现,如果使用内联框架元件引用原型页面,则会出现页面中的交互事件不可使用的情况。
希望及时修复。
谢谢
你好,
希望及时修复。
谢谢
Hi @xiaohui-li,
I’ve translated your message to:
Hello,
In the process of using the latest version of Axure software, it is found that if the prototype page is referenced by the inline frame component, the interaction event in the page will not be available.
Hope it gets fixed in time.thanks
By “inline frame”, did you mean Components (called Masters in RP 9)? Would you be able to post your .rp file here or to support@axure.com so we can further investigate? Thank you!
非常开心收到您的回复!
我提到的“内联框架”是“Inline Frame”,今天我又重试了一下没有再次出现此问题。持续关注一下,如果再次发现我将发送到您指定的邮箱中。
谢谢😌
Hi @xiaohui-li,
Very happy to receive your reply!
The “inline frame” I mentioned was “Inline Frame”, I tried again today and the problem didn’t reoccur. Keep paying attention, and if I find it again, I will send it to your designated mailbox.
Thank you
Thanks for clarifying! Please do let me know if you do run into the issue again. If it does recur, feel free to post the .rp file here or email it to support@axure.com if it contains sensitive content.
