Best practices for managing complex interactions in large Axure prototypes
Hi everyone,
I’m working on a fairly large interactive prototype in Axure RP and I’m starting to run into issues with managing complexity as the project grows.
The prototype includes multiple dynamic panels, conditional logic, and reusable components across several pages. One of the internal test modules I’ve been using for interaction behavior is labeled geometry dash iphone , which I use to simulate fast user navigation and rapid state changes across screens.
Current setup:
  • Multiple linked pages with shared components
  • Dynamic panels with nested interactions
  • Variables controlling UI states
  • Prototype published via Axure Cloud
Challenges:
  • Interactions becoming difficult to maintain as complexity increases
  • Repeated logic across multiple pages
  • Hard to debug state changes in dynamic panels
  • Performance slowdown in heavier prototypes
Questions:
  1. What is the best way to structure large Axure projects to keep interactions maintainable?
  2. Do you recommend using global variables vs local page-level variables for shared logic?
  3. Are there best practices for reducing duplicated interactions across pages?
  4. How do you manage debugging in very complex prototypes?
Would really appreciate any advice or workflows others are using.
Hi @kaileyketchum,
Thanks for your post.
One thing to consider is whether the prototype should be a single prototype that includes all of the interactions or if it can be multiple prototypes separated by use case or feature. If it can be the second, that can greatly simplify the interactions per page and avoid the complexity and slowdown.
  1. When it needs to be the first, using components is likely the best way to manage the complexity. If you can isolate a good amount of interaction within a component and verify that it is working, then hopefully you can trust that it will work as expected when placed on a page. Using “raised events” can expand the scenarios where you can create a component. Also nesting components can be helpful to further isolate interactions. A tradeoff here is sometimes the components get so robust that adding a bunch of them to a page can slow things down.
  2. Global vs local variables… I lean towards the smallest scope possible. So if I can make it work with a local variable I try to do that. Global variables have historically been for passing data across pages, but their use has expanded over time. One feature to consider is the variable changed event. If you select the page, and add an interaction, you should see options for “On[VariableName]Changed”. Essentially, you can trigger a set of conditions and actions by setting a value on a global variable. That can help with reusing logic.
  3. That is what components are meant for. Components also support variable changed events for global variables which can be used to create “functions” on every page the component is used.
  4. When previewing, there is an Interaction Console that you can use to debug interactions, but if things get particularly complex, you can build things into the prototype interactions specifically for debugging, like printing values onto a widget or reading values from text fields that are not a part of the actual design, but make it easy to change variable values for testing.
Just some thoughts!
For debugging, I’d add a small debug master or component rather than trying to trace interactions in the outline. Put text fields bound to the key global or page-level variables and a short label for the active panel/state, then toggle it with a global Boolean. When rapid navigation changes states, the overlay shows which variable or panel did not update. Also name interactions consistently and add brief descriptions to reusable components so they are searchable. This won’t solve performance, but it makes state bugs much easier to isolate.
