Hi, I want to create a way for users to bulk edit droplist options in a repeater from another droplist. It works fine except the fact that all rows in a repeater get changed. How can I change only marked rows?
If I’m understanding you’re trying to do, you need to store the “option” value in the repeater and use it to set the option for the droplist inside the repeater.
The “outside” droplist edits the stored value in the repeater for any row that is marked.
Update_Droplist.rp (57.2 KB)
Thank you very much, this solved my problem
