I’ve not used snapshots much, but I like the concept. The bigger issue for me is that panning and zooming large screen flows in the browser is so difficult and klunky, so I use other tools like Miro which work much better for this.
Yes, you can use the Connector Tool to easily create arrow lines connecting any widgets, including snapshots. As you move the widgets around the connector lines stay connected–and you can reflow them by right-clicking on a connector line. You can create custom styles for these, including various arowheads, colors, line weights, dashes, etc. in the STYLE pane and Style Manager (including the default Connector style.) More info here: Axure Docs · Documentation and tutorials for Axure Software's products and services
Bonus : If you right click on your snapshot (or any widget) and select “Edit Connector Points” you can move them around, add/remove points, etc. --including moving a connector point “inside” the widget–such as right on a button in the snapshot’s reference page–very handy.
I have noticed if you just drag in a snapshot widget, double-click it and set the reference page, then resize the snapshot widget it gets blurry–just like trying to scale up an image. But, if you size the snapshot widget to the full size of your “screens” (The contents of your pages and/or reference screen size), then double-click to set the reference page, they are sharp.
This reminds me of an old technique I came up with back in the RP5 or RP6 days before snapshot widgets…I totally forgot about this… I basically created this manually by taking a screenshot of a prototype page and loading that image in a “screen flowchart” page. Then I created a dynamic panel from that image, and added a state above it–and in that state I would drag in a page from the outline (creating a flowchart box which auto-links to that page.) Then I would create an OnContextMenu or OnDoubleClick event to “bring This to front” then “set state of This to next, wrap”. …All of this made for a “poor man’s zoom” to easily swap between the box and full size screen view.
You should be able to do the same thing with a snapshot. Create a full size snapshot, assign a reference page, create a dynamic panel from that, duplicate State1 to State2, then resize the snapshot in State1 to a thumbnail size. Then assign an event–other than OnClick (like OnContextMenu for a right-click, or even OnSwipeUp) to set the dynamic panel’s state to “Next, wrap”. If you want to override the “click to link to the reference page” you should be able to use the OnMouseDown event. Once you get this working the way you want, you can just duplicate this dynamic panel (Copy-Paste or Ctrl+Drag) and double-click the snapshot widget in each state to link to another page. …Then add your connector lines.
If I find time soon I’ll try this out in RP8 and RP9 and post a demo. This could make snapshots useful for me and my team.
