When you’re in the Condition Builder, I’ve discovered a while ago (just getting around to reporting it now) that you MUST select the operator with the mouse in order for the value to be correct when you click okay.
To Reproduce:
- Add Condition to something
- Use the keyboard to select all the options, be sure to pick something other than equals for the operator then hit enter when you’re done
- Note that your chosen operator isn’t recorded
Interestingly, it is correctly recorded if you open that condition again or add subsequent conditions to the shape.
