[BUG REPORT]Axure's IsValueNumeric cannot validate negative numbers
Axure’s IsValueNumeric cannot validate negative numbers
_exprFunctions.IsValueNumeric = function(val) {
var isNumericRegex = new RegExp("^[0-9,\.\s]+$", "gi");
return isNumericRegex.test(val);
Can be changed to:
if (typeof val === 'number') return !isNaN(val) && isFinite(val);
if (typeof val !== 'string') return false;
return /^\s*[+-]?(?:\d{1,3}(?:,\d{3})*|\d+)(?:.\d+)?(?:[eE][+-]?\d+)?\s*$/.test(val.trim());
Optimization notes:
Supports scientific notation: Added (?:[eE][±]?\d+)? to support formats like 1.23e10, -5.6E-3, etc.
Retains all original functionality:
Positive/negative numbers (±)
Thousand separators (1,000)
Decimals (.123)
Leading/trailing whitespace handling
Stricter validation:
Scientific notation must include an exponent part (e/E followed by digits)
Supports positive/negative exponents (e.g., 1e+10, 2E-5)
Performance optimizations:
Uses native regex literal
Early type checking
Automatic trim() handling
This version provides the most comprehensive number format validation while keeping the code concise.
Hello @Jorkin,
Thank you for writing in and reporting this issue! I have submitted this issue as a Bug Report, and we will let you know if there are any updates. Thank you!
