Hello @Jorkin, thanks for bringing this issue to our attention! I’ve passed it on to our engineering team for further investigation!
Hi @Jorkin, I wanted to let you know that our QA team is currently investigating the issue you reported, and they found a workaround–if you add the “Wait” action between the “Set image” actions, the interaction should be carried on as expected:
I hope this information helps!
Thanks for the suggestion, it’s indeed a smart solution.
In addition, you can also set the image outside the repeater when the internal components of the repeater ONLOADED.
set image outside repeater.rp (49.2 KB)
But I still think this is a bug.
Thanks again.
