I’ve noticed a lot of glitches with shadows in Safari on my Mac since switching to Axure 11. Sometimes they are delayed or have bits missing when they load.
It seems like the issue might be related to how Safari handles certain shadow rendering properties in combination with Axure 11. Here are some ideas to help fix or mitigate the problem:
Try other browsers
Check if the issue occurs in other browsers like Chrome or Firefox. If it works fine there, the problem is likely specific to Safari.
Update Safari and macOS
Make sure you're using the latest version of Safari and your operating system. Older versions may have bugs with CSS or graphic rendering.
Adjust settings in Axure
Simplify the shadow effects or reduce their complexity.
Modify the prototype output settings (e.g., disable animations or transitions for shadows).
Disable hardware acceleration in Safari
Go to Safari Preferences > Advanced and turn off "Use hardware acceleration." This may impact performance but could resolve rendering issues.
Report the issue to Axure
If the problem persists, consider submitting a ticket to Axure. They might already be aware of this issue or have a specific solution for it.
Hope this helps! Have you noticed if the issue happens with specific configurations or projects? That could also provide some clues.
