选中效果控制了边框的可见性,设置时正常,浏览器查看时,边框没有正常隐藏。
Hi @carejoe,
I’ve had to translate your message so I apologize in advance for any miscommunication.
Bug: The selection effect controls the visibility of the border and does not take effect when viewing.
The selection effect controls the visibility of the border, which is normal when set. However, when viewed in a browser, the border is not hidden normally.
To investigate the border issue, could you first make sure you’re running the latest build of RP 11? The latest is 11.0.0.4122. If you are running the latest build, please email support@axure.com with the .rp file you’re seeing the issue with so we can take a closer look. Any additional details you’re able to provide (e.g. screenshot, browser used to preview) will be helpful as well. Thank you!
