Axure8.0,can not change text’s color. anyone knows? Thank u.
yes it can,
select the text widget you want to change on behaviour,
choose behaviour (on click and so on…)
in the case editor select “Set text” , choose your widget in the list
Below where you select your widget, you find “Set text to”. and a dropdown, change that dropdown to “rich text”, then press “edit text” button that appears beside the dropdown. There you can change format of your text.
/Z
