I am trying to edit Textfield Style and add padding so that the text didn’t stick to the field edges. However, the padding is disabled and can’t be edited. Is it possible to indicate it?
Can't edit padding in Textfield's Style
Hi nornaurd!
Some styling options for form widgets, such as text area widgets, are limited in Axure RP 8. If you wanted this widget to display as if the text was not at the edge of the text area, then you could add a widget to display behind the text area widget, so that it appears as if there’s some padding added to the text area.
However, I also wanted to mention that form widgets have some additional styling options (including padding!) in Axure RP 9. If you have not already done so, you can download Axure RP 9 and try a 30-day trial for Axure RP 9 from our site here.
I hope this helps!
system
closed
#3
