Can't select elements below another element
prior to RP9 I could select an element then click again to select the element below it. This is now gone and it’s very difficult to select lower layered elements. Please bring this function back!
They seem to have replaced this ability by the way that Sketch does it. If you right-click on something and choose Select Widget, you get a list of every widget that is under the clicked obect. Here I right-clicked on a checkbox that is above a field which is above a rectangle:
I actually prefer the way they’ve implemented it. In Ax8 I was always clicking multiple times get the widget I needed. Often clicking off to unselected and trying again. So I much prefer this method.
