Could anyone help me build this widget?
Tks
Hi vannucci!
Could you tell me a little bit more about how you would like this prototype to function? For example, are you interested in having the smaller widgets expand to a larger size when they are clicked? Would you want the larger widget to collapse to a smaller size when something like this occurred? Please let me know what kind of functionality you’re looking for, and I’ll be happy to assist!
Hi Chelsea, how are you?
I would like it when clicking on an item expands it and closes what was expanded … do you understand?
The first item must be opened.
thank you very much for your help.
Hi -
Here’s a demo file (that I came across from somewhere) that should help. It showcases a vertically-stacked accordion, but you should be able to see how the “push-pull” works, which you could implement for your design.
Always, hope it helps.
TG
accordion test (expand and collapse one at the time).rp (61.9 KB)
@vannucci,
in addition to the solution above you could also archive this with different states in a dynamic panel.
expandCollapse.rp (94.1 KB)
