Hi Friends,
I have rectangular image with border as a panel which contains 2 radio button (Yes and No).
When user click radio button “Yes” - shows calendar field.
When user click radio button "No’ - hides the calendar field, shows the text-box below and a drop-down. Also, background image height must change to show as panel and to accommodate all the above.
Problem - Not able to change the height of background by swapping small background image to big background image. Background image must change to small when I click radio button “Yes” and vice versa.
Note: I have no issue in doing the interaction, so that is fine. The only challenge to change the background height.
Another issue is since there is a widget below the small panel box which also have to push or pull based on the interaction.
Need your help guys.
Regards
