Hi all,
I have a repeater object and am trying to find a work around to change the text color of a repeater item - BASED on a specific value of the SECOND character in the string (index position 1) being “L” . I am putting the check on the load event on the individual item inside the repeater.
Basically, I want to add a condition that checks that second character for each item and then uses the setText - to rich text that I basically put the same repeater item and just change the text color. What I am having trouble figuring out is how to set up the statement in the condition builder fx panel.
In the condition builder, I have created a local variable that contains the text on my repeater item, and am unsure about the next part,
so far:
if text on This contains “[[LVAR.charAt(1) == (L)]]”
I don’t think I’ve got this statement quite right, any pointers would be much appreciated!
Are you setting the text from one of your repeater columns? If so, you could also set up a conditional case in the repeater’s OnItemLoad event, to check and see if the second character in the column == ‘L’.
The statement would be: If [[Item.Column0.charAt(1) == (‘L’)]] equals true, and then you could set the text to red.
In the OnItemLoad event… the first case sets the text to Rich Text with a red color, the second case (Else if true) sets it to the normal text color:
Thanks so much for the help! I tried using the value condition vs text on widget condition, I had an array of 25 two digit values that I needed to check the second character value and color it differently depending on what condition it met - The suggestion offered above seemed to handle this perfectly.
