Add support for color variables , allowing users to assign a single color variable to multiple components and update all instances of that color through one central configuration.
Problem Statement
In the current setup, users must manually update colors across individual components whenever a color change is needed. This repetitive task is time-consuming and prone to inconsistencies, particularly in larger projects. The lack of a centralized color variable system also makes maintaining and iterating on design systems more challenging.
Indeed, it would be better if it were officially supported, as the colors that are currently changed through javascript cannot be used for alien graphics such as triangles
