@enjoni
I can’t see your file as I haven’t upgraded to Axure 9 yet, but based on the jsfiddle I have an idea.
I approach it something like the following, however the following may not work 100% as expected, depending on how exactly your sliders work. You’d have to modify the Move, Set text or both to fit your requirements.
You could do this with Properties > OnMove and add if statements to your OnMove event. You would evaluate the sum of the other 2 sliders to the one you are moving.
if "[[Slider1.value + Slider2.value + Slider3.value]]" is greater than 100
And "[[Slider2.value > Slider3.value]]"
Set text on (where your value is stored for Slider 1) "[[Slider1.value + This.scrollX]]" // If you're storing the values
Set text on (where your value is stored for Slider 2) "[[Slider1.value - This.scrollX]]" // If you're storing the values
Move Slider2 by "[[This.scrollX * (-1)]]"
else if "[[Slider1.value + Slider2.value + Slider3.value]]" is greater than 100
And "[[Slider2.value < Slider3.value]]"
Set text on (where your value is stored for Slider 3) "[[Slider1.value - This.scrollX]]" // If you're storing the values
Move Slider3 by "[[This.scrollX * (-1)]]"
I’m sorry but i can’t save Axure 9 Files to Axure 8.
I tried your suggestion but I can not get it to work. Maybe my slider works differently. I made some Screenshots of my file I hope it helps to understand my problem.
Looking at your example I would remove:
Set Text
Percent1 to “[[Slider1+This.scrollX]]”
Percent2 to “[[Slider1+This.scrollX]]”
You need to add 1 more if case:
NEW3
Else IF “[[Slider1+Slider2+Slider3]]” is greater than “100” and “[[Slider2]]” is equal to “[[slider3]]”
Move Switch2 by ([[This.ScrollX*(-0.5)]],0)
Move Switch3 by ([[This.ScrollX*(-0.5)]],0)
Copy everything under OnMove and place it under the OnDrag Case 1.
