I recently downloaded 11 and just this morning reinstalled it after being prompted to update for bug fixes, so I believe I have the latest version.
The behavior I’m seeing is kind of twofold – first of all, the default “connector” does not have any arrowhead on the line at all, so if you are making a flow diagram and click the “draw connecting lines” icon to connect shapes, it no longer has any arrow on the line, which isn’t great for a widget specifically designed for flowcharts.
Second, if you select the line and then add arrowheads as a style, it adds them to both ends of the line. I’ve been toying with this for about a half hour and can’t find any way around it. I can’t deliver a flow diagram to someone like this –
From my screenshot, I have an arrow head on the left end and no arrow head on the right end. If that’s different from what you’re seeing, could you reach out to our support team at support@axure.com so we can further investigate? Please also let us know the build of RP 11 you’re running (“Help > About Axure RP”) and the OS (e.g. MacOS 15.5, Windows 10, etc.). Thank you!
Ah, ok, I had to stare at that screenshot for a good few minutes but now I see what you mean. For anyone else here, the styles pane actually allows you to pick a style for each end.
