I’m new to Axure and testing different solutions I now and then want lift widgets from a dynamic panel that I have created. Is there a way to keep the widgets from the panel but remove the dynamic panel itself?
The best solution I found is copying the widgets and pasting them outside the dynamic panel. But then some interactions disappears.
(If I’ve just created the dynamic panel there’s no problem, I just hit the Undo command. My issue is when I some time later want to remove the dynamic panel but keep its contents.)
