Error when copying svg file code and dragging in svg file
Hi matao, thank you for reporting this! I haven’t been able to reproduce this issue on my end, so I’m hoping I can get some additional details from you.
- Does this occur with all .svg files or only specific ones? Can you attach (or email to support@axure.com) an SVG that is causing this error for you?
- Is there a particular application you are copying SVG code from?
- When you are dragging the SVG into RP, are you dragging it directly from File Explorer? Do you see the same errors if you add an SVG from the library or import one into an image widget?
