I’m 99% sure I’ve seen this here somewhere before but I can’t find it.
Here’s a very simple implementation of a dynamic panel drag with momentum and drag. The one weird thing now is it doesn’t reset if you change directions while dragging so you’ll see some counterintuitive behavior if you do that.
It’s kind of fun to play with and I think reasonably mimics some of the physics-enabled drag behavior seen in some mobile OSes and apps.
This is awesome, but there’s a much easier way to do this.
[ol]
[li]OnDrag move with drag [/li][li]On dragStop move by X: DragX / 2 * 20 | Y: DragY / 2 * 20 (the /2 is just attenuating the impact the drag speed has. Think of it as gravity)[/li][/ol]
DragX and DragY are already the X and Y velocity of the mouse, so just use that off the bat!
This also eliminates the strange behavior you noticed.
Very cool, Matei, that is simpler overall. The reason I went with the approach I did is when you use it with a touch device you can “fling” it and “catch” it again mid flight, arresting its momentum. I originally did this to mimic mobile OS-like scrolling behavior. Though this is only apparent right now if you move the mouse again after “catching” it, some tweaking to be done there.
But I think I could probably simplify it as you mentioned.
Yeah the thing I’m currently not wrapping my head around is how to best break up the post-release movement into quantized chunks and how much it should move for each so the check if the user has grabbed it again can be run at each step. I’m sure it’s pretty simple but I’m not seeing it yet.
I think that the only way to do it currently would be to have a loop that on drag drop moves a helper by 0,0 which onmove will move the main item by a small pixel amount, then moves itself by 0,0. pair that with a global variable as a loop checker to restrict it from moving infinitely, and you can check for grabs in that helper.
Easing would be a pain, but i think still manageable if you store the dragX on drag drop in a global and use it as a modifier for the small pixel amount mentioned above, subtracting a small amount each time the loop runs, giving it the impression that it’s slowing down.
That’s pretty much exactly how my file works, though it’s built in 6.5 (and I was a couple of years less adept) so the loop implementation may have been less elegant. The helpers are two panels in the upper left. Instead of subtracting a set amount each time, the value in the momentum field is the multiplier for the previous step’s movement.
