This image is on the Axure website, showing a circular blue percentage ring. Is it actually possible to draw a ring with rounded ends in axure?? I don’t believe it is.
If I draw a circle and try to break it apart or edit points of the ring/circle it doesn’t work.
Are there any clever people that can tell me how to create this percentage ring as it is in the axure image (I can create one with square ends by using circles covered by other circles and intersecting it).
Most other softwares let you create a circle with a border and then add extra points to the ring, and then remove the parts of the ring between the connector points that you don’t want.
