Dropdown menu items showing behind homepage background slideshow
Hi everyone. How do I rectify the dropdown menu items showing behind the homepage background slideshow
If you are using Set Visibility to show the dropdown menu, there is an option under “More options” to “Bring target to front”. That might help. If the menu is in a dynamic panel, it may be getting cutoff by the bounds of the panel.
A sample file would be helpful. If you prefer, you can send it to support@axure.com.
Thank you!! it worked
