Hi Vikram
Thanks for this. However I’m trying to adjust a horizontal repeater and hence width, rather than height.
I have however fumbled my way through your original prototype and got some of it working. RP is attached. I’ve added mine as a new panel to the side of yours, changed height references to width and prefixed “CK_” to most things to make it clear what is what.
For this prototype, I will pre-define the text for each repeater item in Column0. I would like to dynamically set the value of “CK_RepeaterWidth” (a replacement for your “additionalRowHeight” column label) based on the total length (actually the pixels used) of the text within the repeater item.
Unlike a variable height, I also need to get the width of the text label inside the dynamic panel of the repeater item (in my version, labelled “CK_textDisplay”) to also expand along with the dynamic panel itself (I basically want to have the text to be on a single line with about 20px padding either side to the border of the dynamic panel).
Obviously you can resize a Dynamic Panel, but I guess some cleverness is needed to resize the text label element itself?
Thanks again for being so helpful, really appreciate it!
repeaterVariableWidth.rp (90.7 KB)
