Hi xingbb!
I wanted to let you know that this is due to a bug that our team already has on file, where this upload error will appear if your .rp file has a special character in the file name. While our teams are investigating this issue, we have found a few workarounds for this error:
Remove any special characters from the file name
Revert to build 9.0.0.3634 by downloading the previous build here:
- Manually upload your file to Axure share, as described in our Axure Share Basics article here.
Hopefully this helps!
Hi–as an update, this issue has been resolved and you should now be able to publish normally to Share via Axure RP. Thanks!
