Hi! It sounds like you’re all running into a known bug that affected Axure RP 9 builds 3658 and earlier. We released a fix for this issue in the release candidate builds, which should allow the settings in the properties popup to behave normally and not pass from widget to widget as you’re currently seeing. If you haven’t already, I’d recommend updating to the latest release candidate build to get the fix along with several other performance optimizations that we’ve released. If you’re unable to update to the release candidate build, then the fix should be included in an upcoming public release build. Hopefully that helps!
