I successfully set up font mappings in one of my files. I created another file and discovered the font mappings don’e persist and had to be created again. Rather than having to remember to do this every time I start a new file, is there a global setting where I can map fonts persistently, so that Axure always retains them?
Unfortunately, no.
What I’ve done in the past is create a template file that I open and use Save As… a new file to start all my projects. You can also change the write permissions on that file on your OS to avoid saving over your template.
True template capability for Axure would be great to have.
Hi tahinicat,
There isn’t a way to do this natively in Axure RP (however Nathan’s approach would be very useful if you’re consistently using the same fonts/settings), so I’ll go ahead and get a feature request submitted for the ability to create and save file templates. Let us know if there are any other features you’d like to see!
