Hi there,
I have a weird problem with text in general. We use the Google “Exo”-Font for a team project, have set up widget styles for everything and built a library. We use both the Windows and the Mac version.
Now whenever I change the text on a widget (Button, Heading, Body - doesn’t matter what) the font-weight is changed automatically WITHIN Axure. The associated style gets an asterisk, as if I have changed it manually. When I reapply the style, everytime looks good. But I really don’t want to reapply the widget style everytime I change text on a widget.
Note: when overwriting text from master, this does not happen. Everything is fine then.
Is this a known bug within Axure? or is it a known “Exo” bug?
I added some screenshots, in the example the heading-weight is changed from regular to thin. Also you can see that everthing looks great when the master text is overwritten.
I tried removing and installing the font again already. I would really appreciate some feedback / help on this.
Thank you!
Kathrin
Widget from Library dragged on screen
Widget after text-change
Widget after reapplying the style
Master dragged on screen
Master after override
