Form fields are not visible when I generate the prototype (viewed in both in Chrome and Firefox).
I’ve had this issue with the text field widget, the drop list widgets, and the button widget from the default library. I’ve confirmed that the border is not hidden on the text field. The widgets are not set to hidden.
The widgets in question can be found on the home page under the “Find the Right Crane for Your Job” section.
I’ve attached the RP file and you can see the generated prototype here:
Untitled Document
password: HIprojects
I have a client presentation on Tuesday, any help is much appreciated!
Rush Crane 1.1.rp (386 KB)
