I was wondering if it’s possible to change the format of the button that shows up when you assign “File” to a text field? I would like it to match the buttons in the rest of my theme.
I was thinking maybe I could do that in the Widget Style editor but it seems that only affects the file name text and the background of the whole widget.
As you don’t actually see the button in Axure so there’s nothing you can do to style it. To be quite honest, it can be a bit of a swine when using css as there is no actual element to target within the rendered html. After the prototype using external changes would be the only way to do it and that would most likely be best achieved using javascript.
This isn’t Vikram’s file, but here’s an approach that may help:
Note that that Gregor’s solution in the above thread does involve a bit of JavaScript, but the same concept should be able to be adapted to cover a “File” textfield with another widget or image.
