We have a long list of global variables in prototype. If there a way I can figure out where they are used and remove variables that are not in use.
Hmmm… There isn’t a usage report feature in Axure RP for global variables, but if you’re trying to verify which ones don’t seem to be getting used then the closest feature that I think would help is the “Console” tab of the prototype sidebar in the browser; if you open up the “Console” tab and check the global variable values as you’re running the interactions on your page, you can verify visually whether some aren’t being used and remove those from the project.
Thank you for your suggestion!
