I thought there was a way to highlight the value of a text box automatically. On click, focus, etc.
When I click into a box, I want to change the whole value, so select all by default is preferred so I don’t have to manually select it.
Thanks.
Thanks.
If you tab to the field with your keyboard, you should find the value selected automatically. To do this when you click the field, use the click interaction to set the focus on the field and check “select text” like so:
Thanks. That checkbox was what I was looking for - I knew I had seen it!
Cheers.
Joe
