Intended Behavior:
I’m working on a card design which has a view button that shows up when you hover over the image area. And when you hover over the button it changes background color and when it is clicked, it should take you to next page.
The issue:
However, none of this is happening, no matter how I try to do it. I’ve tried recreating the button and the card multiple times and multiple ways, but the problem persists. Is this a bug or am I doing something wrong? Here’s the link to the Axure file: https://fufu6d.axshare.com/
More Info:
The reason I’m going the Dynamic panel route is that I’m creating multiple states of the card and certain behaviors that I can define based on where it appears.
I’ve also attached two gifs showing the behavior as well.
Button Default specs:
- Fit to text height
- Fit to text width
- Lock distance between widget and vertical center of group or panel
- Lock distance between widget and horizontal center of group or panel
- Corner radius: 4px
- Font size: 16px
- Background color: #ffffff (70%)
- Border: none
- Left padding: 16px
- Right padding: 16px
- Top padding: 8px
- Bottom padding: 8px
- Text Alignment: Center & Middle
Button Hover specs:
- Background Color: #f2f2f2 (100%)
- Line Color: #ffffff (100%)
- Border Thickness: 2px
