How do I delete a single note in Axure 9? I seem to be able to create notes, format them, assign to widgets and empty the contents, but I cannot delete them.
Hi roope!
You can delete a note in Axure RP 9 by navigating to the Notes pane and clicking on the note so that the entire note is selected. Clicking above the area of the note’s text field can allow for the entire note to be selected:
Once the note has been selected, you can either press the [Delete] or [Backspace] key to delete the note, or you can right-click on the note and use the context menu to select the “Delete” option.
I hope this helps!
