How to create a ring in Axure based on the positions of three points ?
Hi everyone,
I am trying to create a ring in Axure based on the positions of three small circles (A, B, and C), with circle A as the center. I have made the basic code but it doesn’t seem to work. I would like to understand why the code is not producing the expected result and how to fix it.
As shown in the figure, the yellow area is the area I want to draw.
prototype.rp (53.5 KB)
:hearts: :hearts: :hearts:
javascript:(function() {
    var circleA = document.getElementById($axure('@circleA').data('id')).getBoundingClientRect();
    var circleB = document.getElementById($axure('@circleB').data('id')).getBoundingClientRect();
    var circleC = document.getElementById($axure('@circleC').data('id')).getBoundingClientRect();
    var A = { x: circleA.left + circleA.width / 2, y: circleA.top + circleA.height / 2 };
    var B = { x: circleB.left + circleB.width / 2, y: circleB.top + circleB.height / 2 };
    var C = { x: circleC.left + circleC.width / 2, y: circleC.top + circleC.height / 2 };
    var distanceAB = Math.sqrt(Math.pow(B.x - A.x, 2) + Math.pow(B.y - A.y, 2));
    var distanceAC = Math.sqrt(Math.pow(C.x - A.x, 2) + Math.pow(C.y - A.y, 2));
    var angleBAC = Math.atan2(C.y - A.y, C.x - A.x) - Math.atan2(B.y - A.y, B.x - A.x);
    var canvas = document.createElement('canvas');
    canvas.id = 'ringCanvas';
    canvas.style.position = 'absolute';
    canvas.style.left = '0';
    canvas.style.top = '0';
    canvas.width = window.innerWidth;
    canvas.height = window.innerHeight;
    document.body.appendChild(canvas);
    var ctx = canvas.getContext('2d');
    var outerRadius = Math.max(distanceAB, distanceAC);
    var innerRadius = Math.min(distanceAB, distanceAC);
    var startAngle = 0;
    var endAngle = angleBAC;
    ctx.beginPath();
    ctx.arc(A.x, A.y, outerRadius, startAngle, endAngle, false);
    ctx.arc(A.x, A.y, innerRadius, endAngle, startAngle, true);
    ctx.closePath();
    ctx.fillStyle = 'rgba(0, 255, 0, 0.5)';
    ctx.fill();
    var circleA = $axure('@circleA').$().get(0).getBoundingClientRect();
    var circleB = $axure('@circleB').$().get(0).getBoundingClientRect();
    var circleC = $axure('@circleC').$().get(0).getBoundingClientRect();
    var startAngle = 0;
    ctx.beginPath();
    ctx.closePath();
    ctx.fill();
Thank you! It’s so cool! One more question, how can I make it, if I want this generated area to coincide with the yellow area in the graph ?
    var angleAB = Math.atan2(B.y - A.y, B.x - A.x);
    var angleAC = Math.atan2(C.y - A.y, C.x - A.x);
    ctx.beginPath();
    ctx.arc(A.x, A.y, outerRadius, angleAB, angleAC, false);
    ctx.arc(A.x, A.y, innerRadius, angleAC, angleAB, true);
    ctx.closePath();
    ctx.fill();
In addition, why does changing ‘get(‘id’)’ to ‘get(‘0’)’ work properly? In this project, there is only one element for each element. Will the two functions be the same?
Thank you. It was solved perfectly :100: :smiley: :smiley: :smiley:
prototype_new.rp (48.4 KB)
Hello, in the process of making the prototype, I found another problem, that is, when I moved one of the circle to adjust the sector area, the previously generated area could not be deleted, how can I solve it :raising_hand_man: :raising_hand_man: :raising_hand_man:
WX20240723-100025@2x
You typed a wrong name.
I figured out what the problem is, because I typed the wrong canvas id when I defined it. Excuse me.
yes. Thank you! :+1: :+1: :+1:
