Hi all, is there anyway to make an ellipse, when dragged, to follow a circular path. I basically want to make a circular slider (colour wheel) so the user can select a colour by dragging it around.
Many Thanks
Many Thanks
Here is a dynamic panel that rotates when you drag the circle inside of it. If you want to find out what the current rotation is (between 0 and 360), use the OnRotate interaction of the outer dynamic panel (“rotatingPanel”) and test for the value [[This.rotation]]. You’d put this on top of your color wheel.
Note that there is a do-nothing OnDrag interaction on the outer panel that just prevents you from dragging the image in the browser. Note: make sure the outer dynamic panel is NOT set to “Fit to Content”
File: rotate_panel.rp (66.9 KB)
