I have created a navigation menu with order as Home, Category, Program, Brand, Reports, Now I want to re arrange the order as Home, Category, Brand, Program, Reports with all sub menus. Is there a way to do this in Axure.
Hi Ganesh6samy,
Would you be able to post a copy of the RP file you’re working with? That’ll help us get a better idea of what you’re going for. You can also send it over in an email to support@axure.com if you’re more comfortable with that!
It all depends on how you created you menu. The following ideas popped up to me.
Dynamic Panel: Use different states with a different order.
- Easy and fast & flexible menu structure.
- Duplication of content.
Repeater: Use a repeater for the top menu items. Place subitems in dynamic panel within item.
Use sorting or adding/removing rows to adjust the menu
- Flexible reordering
- Repeater easily gets complicated if the menu structure has more than one hierarchy level.
