Hi, does any know how to send data from a calendar to a different page? Please see the attached image - this is what I’m thinking; hopefully it makes sense. I’m creating a form and want the date selected to show up on other pages. Thank you in advance for your help.
When the user selects the date, set that date to a global variable.
Then on the second page, use the OnPageLoad event to to set text using that variable.
The answer to anything between pages is variables.
Thank you for the clarification - it worked
I am also trying to achieve the something similar, but with radio buttons - so lets say you have a question and then there are yes/no radio buttons. Once the user selects either yes or no then how would I display the results on the second page?
The same way. On the click of each radio button have each set its value into the same variable. Then you can use conditions to do different things on the next page based on the variable value. Since they overwrite the same variable, it will be whichever the user selected last.
Make sure to set a default variable value or handle the empty case.
Hmmm. Didn’t quite work - I think I didn’t quite understand what you were trying to explain.
