This is probably something I’m just missing. I have a model that has a grey background. (I forgot I didn’t have to do the grey but i’m almost done at this point.)
Now I see 2 grey backgrounds. I can’t fine the second one to delete it. The first background spans the entire page, the one that I can’t find the background is smaller. I can see it when I hover over ‘Model’ but it’s not showing up on any stages that I can find.
Thank you for writing in to the Axure Forums! From what I can see, there is actually only one grey background named “Background” contained in State 1 of the “Modal” Dynamic Panel. When hovering over “Modal” in the Outline, it will show the size of the Dynamic Panel itself, which will cut off a portion of this Background as the Dynamic Panel size is smaller than the State with the Background contained within it. I believe it is the same “Background” appearing in both the State and the Modal, it is just the size of the Dynamic Panel limiting the appearance of the Background.
If you delete the widget titled “Background” do you see both of the Backgrounds disappear? Also, could you confirm if there are any issues in the Project Preview beyond what I am seeing here? Thank you!
Thank you!!! I deleted it and added it back outside of the Model panel and changed my interactions and it worked. Thanks for helping me out. I was at a loss. I really appreciate the assistance,
